Multiple Strymon pedals with2 x Pedal power 2+
Posted: Wed Apr 27, 2016 3:44 am
by croznest
Hello could you please tell me if it possible to power 3 Strymon pedals from 2 x pedal power 2+'s?
I have the timeline, mobius and blue sky
Can i use 3 current doubler cables?
If so which number outlets do i plug them into?
thanks for your help as always
Re: Multiple Strymon pedals with2 x Pedal power 2+
Posted: Wed Apr 27, 2016 12:21 pm
The small box Strymon pedals (like the Blue Sky) can each be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal using one of the included all black standard Barrel cables.
The larger box Strymon pedals (like the Timeline and Mobius) can each be powered using a
Current Doubler Adapter connected to output 5 or 6 AND any other output with the corresponding DIP switches set to Normal together with one of the included all black standard Barrel cables.
So with two Pedal Power 2+ units and two
Current Doubler Adapters you would be able to power all three of these pedals.
If you don't already have two Pedal Power 2+ units, you may want to look at our other power supplies... .. Digital, 4x4, and Mondo... each one is capable of powering at least 4 Strymon pedals at once with no adapter cables needed.
