I have a PP2+ and have been powering my Flashback X4 with the current doubler cable on 5 and 6, but now i have a Digitech Ricochet and MXR 10 band EQ.
I've seen people on here saying they use just either 5 or 6 and move the switch away from normal?
The Ricochet literature is saying it takes around 230 ma, but I'm hoping less than that.
The MXR is an 18v pedal with a low current draw, and it looks like i'd have to run that off the aux power?
Help, please and thanks.
Edit: The Ricochet and Flashback seem to power up fine running on 5 and 6, so unless it's a false positive (a Whammy IV powered up but still didnt work), I'm good with those two.
Ricochet, Flashback X4, etc on a PP2+
Pedals
Line 6 HX Effects
Tone Job Earthquaker
Analogman King of Tone
Dunlop wah
Amps
Splawn Quick Rod
Bogner Ecstacy
Fractal AX8
Bogner 4x12 and 2x12
Line 6 HX Effects
Dunlop wah
Amps
Splawn Quick Rod
Bogner Ecstacy
Fractal AX8
Re: Ricochet, Flashback X4, etc on a PP2+
You can power the Ricochet and the X4 each directly from a Pedal Power 2+ output 5 or 6 with the corresponding DIP switch set to Normal, no problem!
The 10-Band EQ can be powered using a Voltage Doubler Adapter connected to any two outputs with the corresponding DIP switches set to Normal.
The Whammy 4 requires AC power and cannot be powered from the DC outputs of the Pedal Power 2+.
Yes, i ordered a voltage doubler cable and now i think I'm set as long as the X4 doesn't crap out using 5/6 on Normal!
Thanks, John!
Thanks, John!
Pedals
Line 6 HX Effects
Dunlop wah
Amps
Splawn Quick Rod
Bogner Ecstacy
Fractal AX8
Line 6 HX Effects
Dunlop wah
Amps
Splawn Quick Rod
Bogner Ecstacy
Fractal AX8
