Hello,
Can I use a power strip with the AC out (on the PP2+) to power my EH Mistress, BK Tube Driver, and TC Elec Chorus?
All use the Two prong outlet
Dan
PEDAL POWER 2 PLUS AND POWER STRIP
Re: PEDAL POWER 2 PLUS AND POWER STRIP
Yes cant see any problems there.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
What he said. Should be no problem.
There is a 200 Watt maximum when using the Courtesy Outlet. Simply add up the maximum power consumption of each device you wish to power... this is usually labeled on the power supply somewhere... as long as that sum is less than 200 Watts then there is no problem. By the way, the 200 Watt maximum is quite high and will likely not be of any concern when powering multiple wall warts.
also...
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=781
also...
Thank you for the info - It helps a alot!
I apologize for the duplicate post.
