GCX switching from the GCPro
fotsband74
Post by fotsband74 »
I have a GCPro and 2 GCX's and 13 non-MIDI stomp boxes. Can I set up the GCPro to switch from GCX1 to GCX2 on the fly?
Re: GCX switching from the GCPro
The Ground Control Pro will control up to four GCX switchers... so two isn't a problem ;)
If you are referring specifically to the Instant Access buttons then you would have eight buttons for direct access to the eight loops you needed most, but your presets can recall up to 32 loops at once.
fotsband74
Thanks for the help. I'm trying it out tomorrow using the presets and instant access modes. It looks like this will be what I need for a while until I program some MIDI devices into it.
