I just bought Pedal power 2 plus and voltage doubler cable PPEH24. I want to power Electro harmonix Bass Micro Synth, old 24V version. The original power supply is 24V 100mA. Will it be ok to power it combining 1 and 2 output of PP2+ (DIP switch ON) - max current on this two outputs with dip switch ON is 60mA?
Jaka
Powering EHX Bass Micro Synth 24V version
Re: Powering EHX Bass Micro Synth 24V version
It would be no problem to use any two of outputs 1-4 on a Pedal Power 2+ with the corresponding DIP switches set away from Normal to power the Bass Micro Synth. It does come with a 100mA supply originally, but it's actual current draw is much lower.
