Pedal Switcher power supply: specs
braveheart
Post by braveheart »
I bought a pedal switcher (9V AC) used with no ps...
So I need a new one: What exact specs does the original power supply have?
How much current do I need?
Thanks Olly ;)
Re: Pedal Switcher power supply: specs
The power supply that shipped with the original 4 button Pedal Switcher was 9VAC @500mA with a 2.5mm Barrel plug. However, the Pedal Switcher will accept 9V AC OR 12V DC and draws less than 200mA.
We do still have stock of the original power supply (its the same power supply that ships with a Ground Control Pro). Feel free to give us a call or write to info@voodoolab.com if you would rather just get a replacement from us.
