Pod HD Pro + GCP (midi command question)
borehead
Post by borehead »
Hi!
I recently purchased a Pod HD Pro and Line 6 finally made it compatible with all MIDI foot controllers.
I actually haven't used the Pod until now, 'cause I needed that functionality. Used my Boss GX-700 for our recent tour.
But now I will start and program my HD Pro. In the HD Pro, you have something called setlists. And in the setlists, you have different presets.
My question is:
To call up a setlist, Line 6 explains in the manual that you "send a Bank Change CC0 (Bank MSB), CC32 (LSB) message with a value of 0 (for setlist 1), 1 (for setlist 2), etc., followed by a Program Change message (Value 0-63 for Preset 01A-16D), for the desired Preset within the Set List. The Set List and Preset are loaded on POD HD Pro."
Does the Ground Control Pro support these messages? I am not at all familiar with "Bank Change CC:s" or "Bank MSB" or "LSB".
I am very much grateful for your help, because this will make my gigging so much easier.
Regards from Sweden,
Johan B
borehead
stilwel
Re: Pod HD Pro + GCP (midi command question)
Post by stilwel »
You won't be able to switch setlists with the GC Pro.
My advice is to setup all of your custom presets in the SAME setlist.
Sending PC's from the GC Pro will give you access to all of the presets within that setlist.
