I wonder if I can use a cable plugged into GCX #3 Loop 8 (mono) and Y instead of I do to connect three points on three amplifiers simultaneously(mono) ?
Help me Jonh !!!!!!!!!!!!!!
Thank you.
Using two amplifiers simultaneously !!!!Help Me JOHN !!!!!!!
Re: Using two amplifiers simultaneously !!!!Help Me JOHN !!!
HELP ME JOHN !!!
You can split this signal multiple ways but at some point you will likely need a buffer to drive the load introduced by connecting to multiple amplifiers and probably some isolation transformers to eliminate any ground loops that can occur.
p.s. You have to post some pictures of this rig sometime... this is one I have to see!
