Hi.
I got my Mission EP-1 pedal yesterday, looks nice and heavy
I use a VoodooLab GCP to control my AXE ULTRA, I would like to connect it to the GCP pedal input same as i used to do with other pedal.
I did that, defined the PEDAL input of the GCP to ON, then went to the AXE - FX ULTRA to define input volume via pedal, I use the "learn" option and the AXE "see" cc #16 but the pedal doesn’t affect anything in the ULTRA.
When I've connected the EP-1 to the PEDAL 1 or 2 in the ULTRA, it works nice, no issues so the pedal is 100% ok.
Does any of you have a good experience with that combination (GCP+EP-1 >> ULTRA) ?
Thanks.
VoodooLab GCP + EP-1 >> ULTRA ?
Re: VoodooLab GCP + EP-1 >> ULTRA ?
If the AxeFx is learning the CC data when you move the expression pedal, then it would seem that all is configured properly within the Ground Control Pro. The next step would likely be programming within the AxeFx so it knows what to do with the CC data.
