Line 6 HD Pro, TC G Major 2, GCX, 4CM, Effects Loop Question
Satch4u3
Post by Satch4u3 »
Hi guys. I recently purchased a new Line 6 POD HD Pro to integrate with my current setup. This is guitar into GCX, which has front end effects from loops 1 to 4. I also have a G Major 2 in the loop of my Mark V, that doesn’t go through the GCX at the moment.
What I am looking to do is connect all devices including the POD HD Pro and Gmajor 2 to the GCX. How would I connect all this to the GCX using the HD Pro with the 4 cable method, while still using my GMajor 2 in the loop as well?
Re: Line 6 HD Pro, TC G Major 2, GCX, 4CM, Effects Loop Ques
What is your preferred signal path?
Will you be using the HD Pro as an alternative preamp section?
Satch4u3
Post by Satch4u3 »
My prefered signal path would be to use the Pod for front end effects and along with the GM2 for post preamp effects. But I would also love to hear a way to hook this up and use the pod as an alternate preamp path.
