GCX not switching loops from GCP
Rax
Post by Rax »
I believe I have everything connected properly.
I'm not getting the information to the GCX to do the switching, but the GCX is passing the midi information through to my delay.
The Active light is on... but none of the 8 lights come on the GCX are on when I click through the 8 instant access buttons that I have set up as loops or momentary switches on the CCP.
So in a nutshell; CCP is changing my programs on a midi delay unit. But the GCX will not switch the loops on or off.
Any idea's?
Rax
"Don't worry about money for the trip back".
https://www.facebook.com/pages/Brad-Say ... 2405167945
Re: GCX not switching loops from GCP
Check what your Instant Access buttons are set to control...
Go into the Setup Mode and press the Instant Access button. The first screen should read "1 GCX 1 Loop 1". that lets you know that Instant access button 1 is controlling GCX #1, Loop 1. If you press the Bank Down button you will see the rest of the Instant Access button settings. Be sure they are all set to control GCX 1.
Let us know if you still run into troubles.
Rax
Post by Rax »
Thank you John.
