Voltage Input?
Voltage Input?
Does anyone know if the GCX audio switcher can handle a 12v power supply?
Re: Voltage Input?
I know the GCX comes with a 9VAC power supply. Personally, I wouldn't risk using a 12-volt power supply, but I'll defer to John for the definitive answer.
- Site Admin
Re: Voltage Input?
You can power the GCX from either 9VAC or 12VDC. A 12V supply is fine if it provides DC, you would NOT want to use a 12V AC supply.nyteowl wrote:I know the GCX comes with a 9VAC power supply. Personally, I wouldn't risk using a 12-volt power supply, but I'll defer to John for the definitive answer.
This is because AC power is specified as RMS voltage. The actual peak voltage is about 1.4 times the RMS voltage. So, using 9VAC we get 12V from the GCX's internal power supply.
Regards,
Josh Fiden
Founder / CEO
