Using the Vox AC30 in GCX loop
Marcus
Post by Marcus »
I have a 30 amp AC VOx and would like to use it in the Voodoo GCX send and return for a given loop.
I remember that the VOX AC 30 has send and return.
How do I use it for example in loop 3 of the GCX can trigger it with a Liquid Foot Pro midi controller
nyteowl
Re: Using the Vox AC30 in GCX loop
Post by nyteowl »
Are you talking about a Vox AC30 amplifier or the Vox AC30 Headphone Amp?
Since you mentioned it having a Send and Return I'm guessing you mean an AC30 amplifier, but I don't understand your question about using it in a GCX loop so you can "trigger" it. Are you using more than one amp and you want to select between them, thus "triggering" the AC30, or do you want to run the AC30's FX loop in a GCX loop and turn the Loop On and Off?
Marcus
Post by Marcus »
That's it. I have another amp to use. Wanted to use it as on / off
nyteowl
Post by nyteowl »
Take a look at the Example 2 diagram on Page 8 of the GCX Manual. It illustrates exactly what you want to do.
Marcus
Post by Marcus »
Ok my brother.
Thank you !!!!!!!!!!!!!!!!!!!!!!!!
