GCX and G.C.P. with Mesa Boogie
boogit
Post by boogit »
Is it possible to control channel switching and other foot controller functions of a Mesa Boogie Roadster with the GCX and Ground Control Pro? The footswitch connects via midi.
Here is a shot of the back of the amp http://mesaboogie.com/Product_Info/Rect ... d-bkLG.htm
Here is some info on the amp http://mesaboogie.com/Product_Info/Rect ... dster.html
Re: GCX and G.C.P. with Mesa Boogie
It is possible to control a Roadster with a GCX or with two Control Switchers. A GCX loop or Control Switcher switch would connect to the External Switch jack for the function you want to control. In this case you have 7 functions, so you would need 7 loops/switches to control everything.
Note: The Roadster footswitch jack is a multi-pin DIN jack but it is not MIDI.
