GCX N00b question
Zuurg
GCX N00b question
Post by Zuurg »
Just starting out with a GCX in my rack and testing things out so there's actually nothing currently connected to my 1-8 connectors.
The problem I'm having right now is that I need to connect the Guitar In on the front of the unit and need to connect the front Feed Thru to the input on my POD HD. When I do this, the output is extremely weak. If I remove the GCX, the output is fine. Am I doing something wrong?
Here's how it's all connected:
Guitar -> Vocalist Live Pro -> GCX Guitar In -> GCX Feed Thru (front) -> Line 6 POD HD Pro.
If I remove the Vocalist from the equation and connect directly to the GCX -> Guitar In -> Feed Thru (front) -> POD, I get a horrible humming coming out of the cabs.
Thoughts?
Anthony
Re: GCX N00b question
Do you have a cable connected on the rear panel from the Guitar Out to the Feedthru?
Zuurg
Post by Zuurg »
No, I don't. Just guitar in on the front and feed thru out on the front.
For your current setup to work, you will need to complete the signal path with a short patch cable connected between the Guitar Out and the rear panel Feedthru.
