help! with my new guitar rack rig
Re: help! with my new guitar rack rig
Maybe this will be easier to follow...
felipe_esp
Post by felipe_esp »
JohnClark wrote:Maybe this will be easier to follow...
thank you so much!!
Oh and on the 1074, I think you may want to use the 1/4" Key Input jack on whichever channel you are using rather than the XLR Input jack.
1. GCX Loop 3 Send to DBX 1074 Channel 1 Key Input.
2. DBX 1074 Channel 1 Output to GCX Loop 3 Return.
I think you will also want to turn On the "Key" button as well as the "Monitor" or "Gate" button... the "Bypass" button should be dark.
felipe_esp
JohnClark wrote:Oh and on the 1074, I think you may want to use the 1/4" Key Input jack on whichever channel you are using rather than the XLR Input jack.
thank you...!!!
i was so busy that i didn´t check the forum since last week.
felipe_esp
thank you...!!!
...but from the dbx output i still have to work with the xlr cable, right?
felipe_esp
thank you...!!!
I ALMOST FORGOT...
any recommendations with cc specific channels or MIDI to use the ADA 1 & 2, g major and the ernie ball vp jr??
thanks...
XLR In is your only choice I believe... does your 1070 have combination jacks by chance?
You will want to assign each MIDI device in your system to operate on its own unique MIDI channel. You have three MIDI devices, MP-1 #1, MP-1 #2 and a G-Major... Id use MIDI Channels 1, 2 and 3 respectively for no other reason than "you gotta start somewhere" ;)
