11r & gcx help
Smayoski213
11r & gcx help
Post by Smayoski213 »
Ok , I am a total idiot when it comes to midi so I need some advice on setting up my system , I’ve read the Manuel’s and they make no sense to me , I’ve watched videos and nothing seems to work ...
What I have....
Hughes kettner tubemeister 18
Eleven rack
Gcx
Ground control pro
What I want to do
4 preset/8 ia
I want to use the ia buttons for individual fx from 11r (od ,verb , delay etc)
The only thing I’ve figured out is how to switch my tubemeister from clean channel to dirty , I can not for the life of me figure out a) how to wire everything b) how to get the gcp to work .
I did have the ia channels working at one point but now that I added the gcx it isn’t working
Re: 11r & gcx help
If it was working before the addition of the GCX then it could be as simple as a failing MIDI Cable or it could require some looking into the MIDI Channel assignments.
Do you know what MIDI Channel and Control Change messages you programmed the Instant Access buttons to use before you added the GCX?
Perhaps we can walk you thru the setup over the phone... give us a call or write to info@voodoolab.com and we can arrange a time to talk while you are with the gear.
