I set up my gcx and gcp yesterday, everything works great except the amp channel switching. The 3ch Smallbox comes with a 2 switch pedal. 1 switch changes from ch1 to CH2, the 2nd switch activates ch3.
The cable I’m using is a Y cable, TRS x TSxTS. TRS in amp channel selector, I’m using loop 1 and 2 on the gcx.
I’m getting ch1 and ch3 but not ch2
On the gcp, it’s set to normal.
I’m sure this is an easy fix but I’m not sure where to start.
GCX, GCP Friedman 3ch SB50 issue
Re: GCX, GCP Friedman 3ch SB50 issue
I figured it out. With no switches pushed on the gcp, it’s on ch 2. It took me awhile to realize that. Everything works awesome now.
