Ground Control Pro Neural DSP's
SneakyAlias
Post by SneakyAlias »
I have a GCX and a GC pro, I would like to be able to control my Neural DSP plugins on my PC with the setup. Is this possible?
Marlboro05
Re: Ground Control Pro Neural DSP's
Post by Marlboro05 »
Hi there,
You are able to, you just need a midi interface to connect to the computer.
I have one of these
https://www.iconnectivity.com/products/ ... tmidi2plus
I don’t know which plugin you have, but I looked at the manual and it shows you how to learn which button does what in the midi section of the manual. I have not played with these but it definitely would be possible.
I checked out this manual
https://downloads.neuraldsp.com/file/fo ... v1.0.0.pdf
Cheers
And some other stuff.
