2nd "pedal switcher" doesn't respond to the GCP?
braveheart
Post by braveheart »
Hello there! :P
My setup (midi) so far was:
GCP - pedal switcher - Line6 M13
now I want to install a second pedal switcher:
GCP - pedal switcher 1 - pedal switcher 2 - Line 6 M13
The 2nd PS doesn't respond (led/loops). The leds work when I switch them on/off manually on the PS and it passes on signals to the M13 via Midi ...
The cables/connections are ok...
What can I do?
Marlboro05
Re: 2nd "pedal switcher" doesn't respond to the GCP?
Post by Marlboro05 »
Hi there,
Have you added the Pedal Switchers as Expanders in the GC Pro? Maybe this is what you need to do?
Cheers
And some other stuff.
braveheart
yes, I enabled it in the setup (expanders)
Marlboro05
Hi there,
I’ve just read the pedal switcher manual, the second pedal switcher is actually loop 5 - 8 of GCX 1. Remove GCX no.2 from the expanders and see how you go.
It’s on page 12 of the PDF
http://www.voodoolab.com/manuals/pedal_ ... manual.pdf
Cheers
braveheart
thanks, that worked! Hiiihaaaaw! :D
