Dual GCX's + GCP Connection Check
dsg2611
Post by dsg2611 »
Hi Guys,
New to the forum and upgrading from a PX-8 to dual GCX units and a GCP.
I was hoping someone might be able to quickly spot check my connections to make sure I've got this planned out properly.
I'd like to be able to switch/blend three amps using loops 1, 2, and 3 on GCX 1.
Any help would be greatly appreciated.
Thanks a lot
GCX 2 - Rear.png.jpg (35.25 KiB) Viewed 3505 times
dsg2611
Re: Dual GCX's + GCP Connection Check
Post by dsg2611 »
GCX 1 Front
GCX 1 - Front.png.jpg (12.85 KiB) Viewed 3498 times
dsg2611
Post by dsg2611 »
GCX 1 Rear
GCX 1 - Rear.png.jpg (34.7 KiB) Viewed 3498 times
Marlboro05
Post by Marlboro05 »
Hi there,
Have you given your setup a go yet?
I can see a couple of things that are incorrect but you may have already found this out.
Your Strymons aren’t in the audio path and your ins and outs are you opposite way around.
If you need some more help, ask away
And some other stuff.
