I recently got the Ground Control Pro and GCX and it works great with the 8 effects I'm running through the GCX and the 8 IA buttons.
I want to add an additional midi controlled looper (something like the Disaster Area DPC-8EZ (GCXs are hard to find here in South Africa but if I can find one I'll get another GCX)
My question is how to I setup a preset on the GCP to use the two different loopers and if I have say 2 compressors (loops 1 & 2) how do I set one preset to use loop1 then the next to use loop 2 but use IA button 1?
I'm sure I can figure it out but I want to know it is doable before I purchase the 2nd midi looper to add additional pedals to the rack
Multiple Audio Loopers controlled by one GCP
Re: Multiple Audio Loopers controlled by one GCP
This can certainly be done, but the exact solution depends on the second switcher and its MIDI capabilities. For instance, with the DPC-8EZ I believe you would control that using presets only as it responds to MIDI Program Changes. This would be saving a combination of loops on the DPC-8EZ itself and recalling that saved combination from a Ground Control Pro Preset.
The Instant Access buttons are global, meaning their programmed function will remain the same across all presets.So if you program Instant Access button #1 to control GCX Loop 2, it will always control only GCX Loop 2.
