Power Supply for Original Ground Control?
modulator
Post by modulator »
I just acquired an original Ground Control without a power supply. What power supply do I need, and is it possible to use the Rocktron 5 pin to 7 pin MIDI cable to run power to it?
modulator
Re: Power Supply for Original Ground Control?
Post by modulator »
OK, I found the answer in a previous post, didn't see it the first time for some reason. 9VAC, at least 500ma. Anyone know the answer to the Rocktron cable question?
