hey, is there anychance someone could use the gcx drawing and show me how to send and return loops to the fx loop on my amp??? just say for example i use loops 1,2,3 infront of the amp, 4,5 to the fx loop, and 6,7,8 infront of the amp or is there a better way of working this???
sorry if this topic has been answerd before, i couldnt find anythin similar so just posted. thanks
how to wire?????
Re: how to wire?????
For this particular setup you would run the amplifier's Effects Send to the In of GCX Loop 4, the Out of GCX Loop 4 to the In of GCX Loop 5, then the Out of GCX Loop 5 to the amplifier's Effects Return.
Although, because you have six loops to be routed before the amp and two to be routed to the effects loop, I would suggest that you use GCX Loops 1-6 in series for the front end effects and use GCX Loops 7 and 8 for the effects loop effects. The wiring will likely come out cleaner this way. I hope this helps!
