grounding/hum issues? post your your tips/ideas here
This is more a generic question related with hum, grounding and even noisy pedals. With modern high gain amps noise is always going to be a problem. My question is what have you personally done to achieve quiet nirvana? Every time I add a pedal into fx loop on my Egnater the noise increases significantly. Cheers Colin
Re: grounding/hum issues? post your your tips/ideas here
I have a few Lehle P split 2 isolation transformers that fixed my ground hum etc. Very very transparent. Couldn't be happier.
