ground control pro channel switching
remco
Post by remco »
Hi Guys
i have a Question i own a ground controller pro
and want to do the following
I have a nice rig Including
triaxis
tc 229
tc gforce
eventide h3500
yamaha spx 90
korg a3
i use my GC with the 4 preset setup
1 on of 2290
2 on of G force
3 on of spx 90
4 on of h 3500
5 on of korg a3
6,7,8 these buttons i want to be able to make channel changes of my triaxis
with my GC
i have tried to make it work by going to instant access select the button number midi channel and then ctl but nothing is happening
any advice would be help full
thanks
Re: ground control pro channel switching
The Triaxis v2.0 will accept Control Change messages but the parameters that can be changed are the "knobs" and they are intended to be controlled with an expression pedal. The channels (Rhythm, Lead1, Lead2) cannot be changed using Control Change messages. Loading Triaxis presets will have to be done with the Ground Control Pro presets.
Resonant Alien
Post by Resonant Alien »
You could get a MIDI Solutions Event Processor ($129). It will map MIDI CC to MIDI PC. The triaxis probably needs MIDI PC messages to change channels - just program the Event Processor to convert whatever MIDI CC is being sent from the GCP to the correct PC for the triaxis.
