I just got a commander so I can control my two switchers. I am probably jumping the gun posting this question. I can't get it to save/change preset programs for some reason. Commander lights work, bank light blinks, preset lights blink, but it won't save anything. All preset buttons do nothing and what ever is selected on the switchers stays the same. MIDI path is
Midi out commander-->MIDI in switcher 1-->MIDI out switcher 1-->MIDI IN switcher 2. Any thoughts?
Commander preset program glitch
Re: Commander preset program glitch
In order to save a preset on the Commander you must do the following:
1. Press any of the Pedal Switcher buttons that should be active for your preset.
2. Select the preset bank you want to save to, 1-5 or 6-10 on Commander.
3. Press-and-hold the Store button on the Commander until it starts blinking (about 3 seconds), then press the desired preset button at the same time.
4. All the LEDs will flash to confirm that the preset has been saved.
Thanks for the reply John. Turns out the MIDI cables where malfunctioning. Three out of four were powering up the commander but not communicating with or between switchers. Fortunately I have a few others. Guess I need one of those cable testers.
