CPro Editor/capability
9vz190
Post by 9vz190 »
I am thinking of buying a GCPro .It all depends on the the Editor that is recommended here on the forum.What can't it do. More specificity, can it arrange presets so i can make up different set lists of 50 plus tunes? Or is just to store a copy of the banks presets in one order, for up and downloading from your computer. If I can not rearrange banks and presets with it ,that would burst my bubble. Not that i am not thankful for the efforts of the individual who graciously shared this with us.
Re: CPro Editor/capability
The Ground Control Pro Editor from Sense Electronics will allow you to save each preset individually and even allow you to save them grouped into specific banks. Creating new set lists is exactly what the creator of this program wanted.
Here is a link to the software... http://www.sense-electronics.nl/?p=gcpe
9vz190
Post by 9vz190 »
JohnClark wrote:The Ground Control Pro Editor from Sense Electronics will allow you to save each preset individually and even allow you to save them grouped into specific banks. Creating new set lists is exactly what the creator of this program wanted.
YYYYIIIIPPPPYYYY!!! THANKS
