spill over
WATRIN
spill over
Post by WATRIN »
Does the GCX allow for delay spill overs, and if so do you need to set it up a certain way or patch it differently? THANKS!
Re: spill over
The GCX by itself will not provide this ability, however a GCX loop can be used to mute the input of a delay routed in a parallel effect loop or into a mixer.
I hope this helps!
cjkbug
Re: spill over
Post by cjkbug »
check out the rjm music mini line mixer. I'm using it with my timefactor and wet reverb with fantastic results. and it takes up VERY little space on a board or rack.
