switching 3 or 4 amps among 3 or 4 speaker cabinets
guitar.player
Post by guitar.player »
Does anyone know of a switchbox that will allow me to blend, mix or match several amps with several speaker cabinets?
If you go to a large stereo store, their listening room will have racks of amps and racks of speakers. To mix and match, you would just press buttons to do the switching. Where can I find a switchbox like that for guitar amps and cabs?[/color][/color]
James Santiago
Re: switching 3 or 4 amps among 3 or 4 speaker cabinets
Post by James Santiago »
guitar.player wrote:Does anyone know of a switchbox that will allow me to blend, mix or match several amps with several speaker cabinets?
The only unit I've seen that works well is the Headbone by Radial. I know a few of our artists that use them live to switch two heads into a single mic'd cabinet.
http://www.tonebone.com/tb-headbone-vt.htm
Just to be clear, switching heads can be very tricky. If you send your guitar signal into a head that doesn't have a proper speaker load on it, you could do some real damage to your amp.
JS
James Santiago
Vice President - Voodoo Lab
