Wiring GCX with a Multi Core loom
Bodie
Post by Bodie »
I want to wire my GCX rack with a loom. Has anyone had success with a multi core cable, that they have purchased? What brand and where? Looking for 16 channel 1/4' straight to 1/4' 90.
I'm considering custom building my own! What is the best cable? Mogami? number?
Bodie
Re: Wiring GCX with a Multi Core loom
What will you be putting into the loops of the GCX... and is your intended layout all set up already?
If you will be simply running pedals in the loops then a snake type cable will likely be more trouble than it is worth simply because the connections to the individual pedals will not be all lined up evenly like the rear panel of the GCX. Also, if this is for a series of pedals, it is possible that all eight pedals will not fit onto a single rack drawer.
