Hi
I want to know if it's possible to control 2 loops (on / off simultaneously) with the same instant access button.
I have a stereo delay that feed two amp, it uses 2 loops and I want to turn it ON and OFF on both amp with the same instant access button.
thanks
control 2 loops simultaneously with one instant access
Re: control 2 loops simultaneously with one instant access
There is a mod that can be done to the GCX that will allow you to switch the state of two loops with a single Control Change message. Write to info@voodoolab.com for more details on how to perform this mod or to have your GCX sent in to have this mod done.
We also offer a Stereo Upgrade board that will convert the GCX loops to Stereo using dual relays for each loop and TRS jacks for all 1/4" connections. A single Stereo Upgrade board will convert four GCX Loops to stereo. Two Stereo Upgrade boards will convert all eight GCX Loops to stereo.
![Image](https://i.ibb.co/kBDjjhH/avatar-sig-green.jpg)
Hi John, is this mod to the GCX (the one that allows it to switch two loops with a single ctrl change) compatible with the older Ground Control (with updated sw) or is it only doable with the GC pro?
Thanx
L.G.
Thanx
L.G.
It is a hardware mod to the GCX... it would be compatible with any controller that can control a GCX.
Interested in this.... the mod is only performed by Voodoolabs or it can be done by yourself? I'm asking because I live nowhere near Voodoolabs...
kidofthecorn wrote:Interested in this.... the mod is only performed by Voodoolabs or it can be done by yourself? I'm asking because I live nowhere near Voodoolabs...
johnclark wrote:There is a mod that can be done to the GCX that will allow you to switch the state of two loops with a single Control Change message. Write to info@voodoolab.com for more details on how to perform this mod or to have your GCX sent in to have this mod done.
![Wink ;)](./images/smilies/icon_e_wink.gif)
