Swap Button Functions on Ground Control Pro?
vkaxeman
Post by vkaxeman »
Any way to configure the Ground Control Pro so that the bottom 4 buttons instead of sending program changes send CC midi changes for stompbox mode? Then configure the Top 4 buttons for Program change?
Re: Swap Button Functions on Ground Control Pro?
The two possible configurations are 10 Presets per Bank with no Instant Access buttons or 4 Presets per Bank with 8 Instant Access buttons on the upper two rows.
vkaxeman
Post by vkaxeman »
Hi John, I am aware of those options and understand how to program as such. But I need more flexibility to program the first row of buttons. Any chance this kind of flexibility is being looked into and will be available with a new firmware update? And speaking of a firmware update, when will the next one be available?
THanks!
Chet
chagmaier
Post by chagmaier »
hope the warranty police arent reading this...you COULD take the back cover off, and see if its possible to swap the physical position of the switches... :)
ive never had mine open, it might not be possible....
Heres an idea...
turn the GCP around, place a book under the end, and use it upside down
