I just think I have to live with the extra noise
Re: I just think I have to live with the extra noise
I've not been charging for the v2 Beta chips since they are not a finalized update and have no real documentation and currently have limited support.
Unfortunately, running the two Ground Control Pro units linked will not send Phantom Power to both. The first one would have to get powered from the power jack. (Or you would have to modify the second one... and probably get a bigger power supply)
Since you are using presets on both units to control different stuff and will lose phantom power to one unit, it probably isn't something you want to do. You probably get more "on the fly" flexibility out of what you are currently doing, but feel free to try it out.
Oh well, Keep it Loud!
carstenlange
I found it, noise issue, i think
Post by carstenlange »
But I cant throw away my washer and Dryer.
So it seems like when I mostly play the guitar it is on weekends, usually Saturdays between 8am and 12pm. My wife usually runs the washing machine around that time.
Today(Saturday) after getting rid of noise when troubleshooting on a Tuesday night, the noise came back. Kepted trying to figure it out, about 2 hours later the noise went away. Washing machine ended its cycle.
I still do get a very very slight bump in gain(white noise increase only from using ISP ProRackg before amp input)
So my Rack and all of its stuff connect to a Furman power conditioner(M-8Dx ). Than that Furman and my PT100 and Bogner XTC plug into another Furman power conditioner (PL-8C). So when I connect directly to PT100 no noise. But Going through rack there is.
But this seems to only be issue when washer and dryer run. How come its not causing the noise issue when going direct?
I have a hum x plug. Havent tried using it but I think I will use it on the Furman M-8DX, (hum x is just one of those resister and cap jobbers that take 60hz and below and shunt to ground I think)
Custom Audio Amplifiers PT100
Bogner Ecstasy 101B
Carvin electric guitars
carstenlange
there are 2 things going on. I am getting the noise from either dimmer lights in my living room or the washing machine dryer.
Had noise come back, had wife turn off dryer and noise was still there, had wife turn off lights with dimmer and the slight crackly/faint hum when away. Turned them back on came back, turned them off went away, but then it never came back( turned it off and on 5 more times to see if noise would come back and it wouldn't.
The other thing that I thought was part of the above issue but its not related to above is the fact that the ISP ProRackG doesn't put out instrument level, it puts out +4 line or -10db consumer.
-10 consumer is still a gain boost compared to instrument level.
I need away to get that -10 consumer level output of channel A down to instrument level.
Bogner Ecstasy 101B
