GCP and GMAJ2 Expression Pedal
stantonj
Re: GCP and GMAJ2 Expression Pedal
Post by stantonj »
I have my two EBJRs wired opposite from one another and they are both working fine. I can't explain why they work backwards but they do... I am not changing a thing on that :)
It is possible that the color coded 1/4 plugs are not colored the same. The only way I could determine that is if I do a continuity test or something like that... However, as I said, I am going to leave good enough alone. I have one for volume and the other for effect-right now the effect is delay but I want to make it work as a harmonizer. I have not yet figured that out.
John, I think you are right about the volume... I will make edits within the GMAJ2 to try to change the sweep in terms of having a muted position to max volume position.
Bend your will to learn midi, then you can bend midi to your will...
I'm good with you leaving it as is since it is working, but something isn't adding up here... I suspect the same, that your Insert Cables are not both wired/colored the same way.
Anyway, Right on!
The G-Major 2 has a "Whammy" setting and getting it set up is shown in the G-Major 2 User Manual in the Mod Menu section. Look to External Control Using Modifiers, then the Assigning an expression pedal as a Whammy example.
In fact, the External Control Using Modifiers section also shows how to change the response curve of an expression pedal.
