GCX and Ground Control Pro - can order of effects be swapped?
Posted: Wed Feb 27, 2019 7:03 pm
I have a GCX and a GCP - seems to work fine, I have it wrapped around an ENGL E530 preamp to where it switches its channels and gain stage, so that works out great. I am also looking to place a few fx before the preamp and a few in the loop. In the preamp I'll have most likely just a tuner and noise gate.
Tuner when activated mutes, so first question if there is a way to run the tuner outside of the loop, without it using inputs of the GCX? The THRU maybe?
Also - can che effect path be changed?
While I am working on this, I've thought that I might want to run say on the GXC in fx loop #5 Chorus+#6 Delay+#7 EQ in some instances and in others I want to have
#7 EQ+ #5Chorus for example, is this possible to program?
