GCX Loop Issue
andrewfoltzmusic
GCX Loop Issue
Post by andrewfoltzmusic »
I sent a query into the info@voodoo labs but since then ive narrowed my problem down to this:
Loop six when put in the circuit in any order causes hum.
Literally any other combination or routing no hum.
When i leave it out the hum is gone.
What could this be?
Is there a problem with the ground connection on the jacks?
Thanks in advance.
Re: GCX Loop Issue
Could be a broken jack... we would be happy to inspect this GCX for you. How long have you had this GCX and where did you buy it?
andrewfoltzmusic
Re: GCX Loop Issue
JohnClark wrote:
Mon Aug 05, 2019 10:48 am
I just got it like two weeks ago , purchased from Reverb used.
Re: GCX Loop Issue
I isn't uncommon to find hidden mods in a used GCX, although I can't think of a common one that would cause this specific problem ;)
We would still be happy to inspect this for you and get it running like it should!
