Wwill px8 switch between 2 amps
Posted: Thu Aug 15, 2019 2:50 pm
by Alabamadog
Can you run 2 amps and switch between the 2 with the px8
Re: Wwill px8 switch between 2 amps
Posted: Thu Aug 15, 2019 4:28 pm
It can if you want strict A/B switching. You would use Loop 8 to be the amp A/B with Loop 8 Send going to one amp and PX-8 Output going to the other amp.
When Loop 8 is Off you will hear the amp connected to the Output.
When Loop 8 is On you will hear the amp connected to the Loop 8 Send.
