Trouble Getting Midi CC Inforamtin Into Preset
dkbarnwell
Post by dkbarnwell »
Hey Folks,
Just got my new GCP...pretty excited! I have a TC GMajor and want to set preset #1 (in the 4 Instant Access Mode) to bypass the unit. I was successful in setting the small #1 button to toggle on/off the bypass but want to build that into a preset and I can't see where to do that. Earlier forum post stated that you could send midi cc information as part of an Instant Preset. I even set the small #1 button to "X-mit w/Preset" which the manual stated to do. Can't seem to make the connection between the two.
Can anyone help me out here?
Derek
Re: Trouble Getting Midi CC Inforamtin Into Preset
You are close...
The next step in order to make a preset activate the bypass is to save the state of your Instant Access button with the Ground Control Pro preset. Here is a quick guide...
1. Call up the Ground Control Pro preset you wish to edit.
2. Press any of the Instant Access buttons that should be active for this preset.
3. Press and hold the Edit button, release it once the screen changes to your device name.
4. Press the Edit button then the Yes button to save the state of these Instant Access buttons.
