GCX/Ground Control Pro Noise issue
Posted: Fri Nov 08, 2019 9:38 am
So, I’m having a issue with noise and the loops on my GCX. I switched the gear I’m using and ever since I’ve had severe noise issues. I switched from rack gear to stomp box pedals. My old setup consisted of a couple of rack mount fx( each assigned to their own loops) going to my amps GC loop along with a boss overdrive in a dedicated loop using the guitar in to the input of the overdrive and the output back thru the thru Jack back to the front of amp. All was controlled perfectly for years with out noise or incident. Now I’ve switched out the rack gear for all stomp boxes in the effects loop and have all kinds of crazy noise. If I remove the overdrive from the setup, the noise goes away. If I put the overdrive in my pedalboard, no noise. Can’t figure this out. All recommendations are greatly appreciated. I’ve owned this setup for over ten years with no issues.
