GCX LOOPS AND RJM PBC10
iceman78
Post by iceman78 »
Hi to everyone, i decided to use my old Ada MP1 together with the mesa V-Twin rack preamp that actually is my main sound. Looking at hte GCX manual i found how to use both very easily but i cant understand how to connect my pedalboard where is the RJM PBC10 that does all the midi and signal routing.
Looking at the GCX manual i thought to do this:
Guitar> Pbc input> Loop5/6 OUT> GCX FEED 1> FEED THRU>MESA V-TWIN> LOOP1 IN
> OUT >ADA MP1 LOOP1 RETURN
>LOOP1 OUT> PBC LOOP 7/10 IN> OUT A-B> INTELLIFEX INPUT L/R> INTELLIFEX OUTPUT L/R >INPUT L/R STEREO POWER AMP> CAB 1 AND 2
Now the idea is to go out form the pbc in stereo entering the GCX where i would have the intellifex in stereo and so going into the power amp.
Someone can tell me how to do this?
I hope to be clear and sorry for my bad english.
Thanks and regards from Italy hping everyone are well.
Stay safe out there
Re: GCX LOOPS AND RJM PBC10
Unless the GCX is modified to have Stereo Loops, all the loops will be Mono. For your setup you will likely just use two Loops for each Stereo Device you want to switch.
I'll use GCX Loops 7 and 8 for an example, but you can use any two GCX Loops you want for the Intellifex:
1. PBC Left Output to GCX Loop 7 In.
2. PBC right Output to GCX Loop 8 In.
3. GCX Loop 7 Send to Intellifex Left Input.
4. GCX Loop 8 Send to Intellifex Right Input.
5. Intellifex Left Output to GCX Loop 7 Return.
6. Intellifex Right Output to GCX Loop 8 Return.
7. GCX Loop 7 Out to Power Amp Left Input.
8. GCX Loop 8 Out to Power Amp Right Input.
