GCP and BOSS FV-500L
Posted: Tue Mar 31, 2020 8:13 am
Hello,
Please... can you help me?
I’m using the GCP with two BOSS FV-500L to control expression.
I’ve connected both pedals with TRS (stereo) cable and using the EXP output on the BOSS pedals.
The problem is when i rock both pedals, the MIDI values goes from 0 to 125... and sometimes from 0 to 124... and never reach the maximum value (127)...
When i use it to control whammy, for example, it never reaches the maximum value and the sound is bad...
I even opened both pedals and removed the “minimum volume” pot... to make it as transparent as possible, but it didn’t solve the problem.
Is there any “calibration” i can do on the GCP?
Or it is just a bad pedal?
Another issue i notice is that the values doens’t change a lot in the begining of the sweep... and most of the changes happens in the end of the pedal travel... like it was a logaritmic taper... but in the specification they say it is a 10k linear pot.
Is there any way to get an even sweep??
Thanks a lot,
Wagner.
Thanks a lot,
Wagner.
