I need some help with this one, I bought the control switcher to switch between 3 channels of my Victory amp clean, crunch & overdrive.
The original pedal for the channel switching is dual latching, I can get the clean and overdrive channel switching perfectly but not the crunch channel. I've used a Y/insert cable, from the switcher which is two mono tr going to trs cable at the back of the amp. Is there something I'm missing? Do I need a special cable made up to achieve it?
Any help would be much appreciated
Control switcher-amp channel switching on Victory V130
Re: Control switcher-amp channel switching on Victory V130
Hi there,
With the original pedal, can you swap the cables and control the other function?
There is nothing written in the Victory manual about the CH/CRUNCH only the Overdrive Voice I/II.
See how you go with this, it with tell us if something else is going on.
And some other stuff.
