POD XT Live, Ground Control setup
Posted: Fri May 01, 2009 5:54 am
I am very much considering purchasing both the MIDI Ground Controller as well as the GCX. However, I am rather new to MIDI and making this purchase would be dependant on being able to use the equipment as follows: My intention is to have a one-stop-shop way to switch among various combinations of equipment (that would all be stored compactly in a rack), including multiple Boss stomp boxes I’ve amassed, clean and dirty channels on one or more amps as well as my POD XT Live (the floor version of the rack Pro), of which I’ve downloaded and tweaked hundreds of presets.
I’m fairly sure this will the use of multiple GCX units, but my real question is, is there available a setup PDF file, like the ones available on this page (http://www.voodoolab.com/gcx.htm), that factors in the use of a POD XT Live , where the POD functionality in the Ground Controller is not turned on (i.e., for the POD, I’m looking to use the Ground Controller to switch among preexisting presets in the POD. Those presets would be edited via the POD, not the Ground controller. So, if I understand how the product works, buttons 1-8 would be for turning loops on and off – not turning on and off POD features such as AMP, COMP, WAH, etc.; switching through the POD presets would be effected by switching through the Ground Control’s banks/channels).
I would also envision being able to use expression pedals for multiple items, including, but not limited to, a Morley Bad Horsie wah, a Digitech Whammy pedal, Volume and Expression parameters stored in preprogrammed POD XT Live presets, etc. First, is the expression capability of the Ground Control robust enough for this; second, is this also something that can be documented in the above requested PDF?
I have spent much time on the internet trying to find information on or about this type of setup (Controller, GCX(s), Expression Pedals, stomp boxes, amps and a POD XT Live) and I’ve not been able to find anything that adequately addresses this. I’m sure it’d be easier if I was using a rack POD Pro (which I presume was designed to be controlled via MIDI), but why do that if I can use the POD I’ve been using with the same end result?
Or, are there any site(s) that I can go to that would help me with my questions?
