Ground Control Pro with Headrush Looperboard
Posted: Wed Jul 22, 2020 6:51 pm
by monnecka
hi I'm new so forgive me if this was covered.. I didn't see it when searching online here
I have the looperboard from headrush and i am trying to get the GCX to work with it. Anyone had any luck with this?
I am basically trying to copy what the footswitches do on the looperboard unit and use the voodoo for this.. i have it working with the behringer fab 1010 but i hate the buttons and the layout.
The Gcx buttons are the same and spread out etc so this would be great if i can get it working.
the issue is the midi CC .. i am assuming i can only control this with instant access etc.. but im not sure.. I can't get it working at all.. hopefully this controller will work for me and im just not doing it correctly
John
Re: Ground Control Pro with Headrush Looperboard
Posted: Fri Aug 07, 2020 2:46 am
by Marlboro05
Hi there,
I presume you mean a Ground Control Pro and not the GCX switcher??
If it is the GC Pro you are talking about, you need to add it to the devices and assign it the midi channel that the Headrush Looperboard operates on or what you have set it’s midi channel to. After this then you can start talking to it with your GC Pro. See how you go, then get back to us
