MIDI Out Not Working Help...
Posted: Mon Aug 17, 2020 5:03 am
Hey guys, I'm hoping there is someone out there who may be able to help with this issue as driving me nuts
I have a Voodoo Lab PX8-Plus switcher which I use to control 8 pedals using the "Preset Method" i.e. controlling different loop combinations using the 36 presets available on the PX8-Plus. I have 3 Strymon pedals (Mobius, Timeline and BigSky) which I'd like to control using MIDI and I'm under the impression that it is possible to sequentially scroll through the presets on these pedals so long as the devices are all set up correctly. Unfortunately, I'm having issues and I can't figure out why as the PX8-Plus seems to be programmed correctly. The MIDI connections for the Strymon pedals are as follows:
MIDI OUT (PX8-Plus) --> MIDI IN (Mobius), MIDI OUT (Mobius) --> MIDI IN (Timeline), MIDI OUT (Timeline) --> MIDI IN (BigSky).
According to what I have read on this forum, when set up correctly, the switcher should scroll through the patches sequentially as follows:
Bank 1, Preset 1 (PX8-Plus) activates Preset A Bank 0 (pedals).
Bank 1, Preset 2 (PX8-Plus) activates Preset B Bank 0 (pedals).
Bank 1, Preset 3 (PX8-Plus) activates Preset A Bank 1 (pedals).
At the moment, nothing is happening via MIDI; as I change the presents on the PX8-Plus, all the Strymon pedals just stay on the same patch. I have been in touch with Strymon and all of the pedal parameters are set correctly to allow MIDI messages thru the pedals; I have set everything to run on Channel 1 and I have enabled both PC and CC messaging types on the PX8-Plus but still nothing is happening.
I have a feeling it is a communications issue between the PX8-Plus and the Strymon pedals - I'm not convinced that the PX8-Plus is sending the program change message via the MIDI OUT port to the Strymon pedals to switch patches, but I'm not sure how I would go about checking this - has anyone else had this problem? I have changed cables (I have tried 5 different cables) and tried connecting the pedals individually as well as chained together and still the problem remains. I have also tried a factory reset of the PX8-Plus and I have the same problem.
Right now I'm out of ideas and it would be great if someone could help as this would be a very useful feature for me.
Any help would be much appreciated, many thanks in advance.
