Multiple Amps and Pedals
Runrmc
Post by Runrmc »
Ok. I’m hoping I’ve done this right.
Gear:
Mesa triple rectifier
Marshall JMP-1
Fulltone FullDrive
Chorus pedal
Line 6 Echo Pro
I need to drive both amps at once. They will both always be used. No a/b, both always on - channel switching together. The chorus and fulltone will drive the front of both these and I’ve also just left the Echo Pro in front as well (I don’t actually own this yet - it might end up being. G-Major 2 but I haven’t had much success with one in the past).
Is this the correct routing?
Runrmc
Re: Multiple Amps and Pedals
Post by Runrmc »
After more thought. Is it easier for me to split the signal going to the input of the boogie with an ABY box and sent it to the input of the JMP-1 as well? I would just use the “out” not the “send”?
Marlboro05
Post by Marlboro05 »
Hi there,
Yes, that will work, the way you had it in the picture is only one amp at a time, out of loop 3 to the y cable into both amps unless you wish to mute them both.
I’d use the chorus and echo after the preamps though and even the GMajor 2 if you end up getting one, but that’s up to you. Maybe have a wet/dry setup.
And some other stuff.
