Controlling Line 6 M5 with Pedal Switcher + Commander
StevieD
Post by StevieD »
Anyone know if it is possible to switch patches within the M5 using the Commander and pedal switcher?
Marlboro05
Re: Controlling Line 6 M5 with Pedal Switcher + Commander
Post by Marlboro05 »
Hi there,
The Commander sends out Program Changes 1-10 with the respective button. So you can choose presets 1-10 only. It also has to be set to Midi Channel 1.
This is from the M5 manual
Midi Control
The M5 will send and receive MIDI CC and Program Change messages on any MIDI Channel from 1 thru 16 or Omni, selectable from the MIDI screen in Setup mode.
Hope this helps
And some other stuff.
