Recently the bank down (select) switch has stopped working on my Ground Control pro.
Has anyone else encountered this fault and does anybody know of an easy fix I can do myself?
If not does anybody know of anyone in the UK who can fix this without charging the earth?
GCPro:Bank down (select) switch not working.
Re: GCPro:Bank down (select) switch not working.
Hey,
Exact same thing happened to mine. Warranty is 5 years so if you're still covered don't open it up. If you're not covered anymore, it's a super easy fix. Open it up and replace the switch.
Send a message to info@voodoolab.com for better details on how you can get this issue fixed as quick as possible.
