GCX/Ground control pro/TC Nova DRive/MIDI
Legacy
Post by Legacy »
Hi guys
1.How do I access saved patches on my Tc Electronic Nova Drive with Ground control Pro?
2.I have other MIDI pedals and I am just wondering how do I save sounds from multiple MIDI pedals?
I'd appreciate any help
Up the Irons !!!
Re: GCX/Ground control pro/TC Nova DRive/MIDI
Both your questions actually have the same answer... within the Ground Control Pro you will name each MIDI device and assign it a unique MIDI channel. Doing this allows you to select which patches are recalled on each device for a given Ground Control Pro preset. Check out the Device Name/Channel section of the Ground Control Pro manual under Setup Mode to configure your individual devices within the Ground Control Pro. After everything is named a set up you can then go on to creating Ground Control Pro presets, the Assigning MIDI Program Changes section of the Ground Control Pro manual under Edit Preset explains this. Let us know if you get stuck before you Run to the Hills ;) .
